SimoniMilloni
Jan 20, 2023Aspirant
AC2000 Wireless Access Point Confusion
I want to use my AC2000 just as an extender from my house to my garden office via the Ethernet cable. So same BT network, same BT password. Instead it keeps on showing the Netgear-1 wireless netw...
michaelkenward
Jan 20, 2023Guru - Experienced User
Which AC2000? That is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Did you follow these instructions?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
SimoniMilloni
Thanks - it’s as follows
AC2000 802.11ac
Wireless Access Point/Router
Model WAC124
AC2000 802.11ac
Model WAC124
- michaelkenwardJan 20, 2023Guru - Experienced User
AC2000 802.11ac
Model WAC124Aha. One of them.
Not your typical Nighthawk Wi-Fi 5 (AC) Routers as covered in this section. In fact, not really a router at all, more an AP with router features.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.- SimoniMilloniJan 20, 2023AspirantThanks - yes I have tried to follow the steps which go as far as telling me how to enable Access Point mode but that isn’t solving for what I’m trying be to achieve above unfortunately
