BDubUT
Jun 13, 2018Aspirant
Antenna Gain for 5Ghz radio on WAC510
On the product page, the WAC510 antenna gain for the 5Ghz radio is listed as 6 dBi:
https://www.netgear.com/business/products/wireless/insight-managed-wireless/WAC510.aspx#tab-techspecs
Howev...
- Retired_MemberJun 14, 2018
Hi BDubUT,
The correct value is 5dbi on the 5Ghz radio, as per the datasheet.
Thanks for pointing this mistake out, we will update the product page accordingly to display the correct value.
Kind regards
DavidGo
Retired_Member
Jun 14, 2018Hi BDubUT,
Kind regards
DavidGo
