rhsit
Oct 05, 2021Aspirant
AX1800 WAX610Y shows configd[3160]: get_cur_channel: None of the interfaces are in UP state for wifi
I have two NETGEAR® Insight Managed WiFi 6 AX1800 Dual Band Outdoor Access Point (WAX610Y)
Have connected 22 Cisco IP Phone SPA525G2, 11 each on each AP
Have enabled only 2.4GHz as the phones support that only
Both have Firmware V9.5.3.2 which is the latest.
I have not done any other modifications on original settings. But both the devices show the below all the times and gets stuck in between and a restart is needed.
AP1
Oct 5 15:35:09 configd[3160]: get_cur_channel: None of the interfaces are in UP state for wifi1
AP2
Oct 5 15:45:17 configd[3169]: get_cur_channel: None of the interfaces are in UP state for wifi1
In AP2 I saw the below message today which I suspect is attack as per my search. please help
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:aa WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:35:bc WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:3e WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:8a WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:18 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:34:b8 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:1c WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:90 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:32 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:35:58 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:26 WPA: received EAPOL-Key frame (2/2 Group)
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:8a WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:35:bc WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:32 WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:1c WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:34:b8 WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:aa WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:3e WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:90 WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:36:18 WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:35:58 WPA: sending 1/2 msg of Group Key Handshake
Oct 5 15:36:26 hostapd: wifi0vap0: STA 00:cc:fc:b2:37:26 WPA: sending 1/2 msg of Group Key Handshake
The "get_cur_channel: None of the interfaces are in UP state for wifi[1|2]" looks like a message I would expect during an AP boot or restart.
The "WPA: sending 1/2 msg of Group Key Handshake" and the associated "WPA: received EAPOL-Key frame (2/2 Group)" looks like a plain common group key encapsulation part during the the WPA 4-way handshake.
Desktop IP phones on WiFi? Shudder .....
- rhsitAspirant
The IP Phones are Cisco connected to this two APs.
Nothing other than the phones are connected to these APs
Only 2.4GHZ is enabled.
Every few hours the accesspoints webpage comes inaccessible. Also the phones gets office.
The access points and the phones need to be restarted.
This none of the interfaces are shown continuously in the logs
