MarcAlain
May 09, 2016Aspirant
Bad WLAN Roaming with WNDAP360
Hello I use 4 WDAP360 APs on 4 different floors, each on different frequencies. I've discovered that especially the Lumia950 but also some notebooks show a bad WLAN roaming behavior. Is there any ...
- May 17, 2016
Hi MarcAlain,
If you want to have the logs of the WNDAP360 be analyzed, you may open an online case with NETGEAR Support at anytime. State your concerns and attach the logs of the WNDAP360 on the online case for it to be analyzed by the engineering team.
I believe the R7000 is a WiFi router and its possible that you can set it up as an access point. Good to know that the WNA1100-N works just fine with the R7000.
DaneA
NETGEAR Community Team
mdgm-ntgr
May 11, 2016NETGEAR Employee Retired
Are you using a Wireless Controller? If so, which one?
MarcAlain
May 11, 2016Aspirant
At the time when I installed the 4 AP Netgear support said it will work without controller.
Do you think it needs one? If so, whoch one do you recommend?
Thanks.
- DaneAMay 11, 2016NETGEAR Employee Retired
Hi MarcAlain,
Kindly answer the questions below:
a. Have you tried changing the wireless channels?
b. How are the WNDAP360 access points deployed? Is it mounted on the ceiling or side wall?
c. Have you tried to unsecure the wireless network configured on the WNDAP360 access points?
d. Are there other wireless networks present in the area where the WNDAP360 access points are deployed?
e. What is the current firmware version of the WNDAP360 access points?
f. What is the distance of each WNDAP360 access points from each other on different floors?
g. Is the wireless connection just fine within each floor?
I look forward to your response.
DaneA
- MarcAlainMay 12, 2016Aspirant
Hi DaneA,
thanks please see in the text:
Yes, automatic channel selection ended up having all om channel 9...
Now I use 5, 10, 1, 13 and 112, 100, 124, 136 from 1st to 4th floor.
Mounted on the ceiling.
Yes, no difference.
It's about 30 to 50 meters to the houses around this one and there is no channel overlapping.
3.5.5.0
Vertical 3,5 meters.
Horizontal between 10 and 20 meters.
Yes, when selecting the explizit name of each AP it's almost max.
MarcAlain
- DaneAMay 15, 2016NETGEAR Employee Retired
Hi MarcAlain,
Is this how your current network is set-up? Refer to the image below:
You may post a detailed network diagram on how everything is connected.
DaneA
