MarcAlain
May 09, 2016Aspirant
Bad WLAN Roaming with WNDAP360
Hello I use 4 WDAP360 APs on 4 different floors, each on different frequencies. I've discovered that especially the Lumia950 but also some notebooks show a bad WLAN roaming behavior. Is there any ...
- May 17, 2016
Hi MarcAlain,
If you want to have the logs of the WNDAP360 be analyzed, you may open an online case with NETGEAR Support at anytime. State your concerns and attach the logs of the WNDAP360 on the online case for it to be analyzed by the engineering team.
I believe the R7000 is a WiFi router and its possible that you can set it up as an access point. Good to know that the WNA1100-N works just fine with the R7000.
DaneA
NETGEAR Community Team
MarcAlain
May 17, 2016Aspirant
Maybe you know somebody who can ahve a look at the log of the WNDAP360 AP?
I'm also willing to pay to resolve this other issue.
BTW, just chekced with a Netgear NWA1100-N and ther too, the connection works well like on the R7000.
Marc
DaneA
May 17, 2016NETGEAR Employee Retired
Hi MarcAlain,
DaneA
