twoods
Aug 10, 2018Apprentice
Brand New WAC510 Keeps Power Cycling
Incidentally, what happened to the WAC510 option in the Model list?
Anyhow I installed a new WAC510 in a stand alone configuration on a Cisco SG350-10P (POE) switch. The acesss point will stay ...
- Aug 12, 2018
Hi twoods,
What is the current firmware version of the WAC510? If ever its not yet the latest version, I suggest you to upgrade it. The latest firmware version is 5.0.0.17 and you can download it here. Be sure to perform a factory reset on the WAC510 after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, observe if the same problem occurs.
DaneA
NETGEAR Community Team
DaneA
Aug 12, 2018NETGEAR Employee Retired
Hi twoods,
DaneA
twoods
Aug 12, 2018Apprentice
It came running V1.5.3.10. I had to take it off the POE switch and connect it to a separate power supply (fortunately I had one from another installation) in order to get it to stop power cycling. I upgraded the firmware to V5.0.0.17 and then, back on the POE switch, it seems to be working normally. ... I have 4 of these WAC510's installed and really really like them!
