Mash123's avatar
Mash123
cannot acces web console admin after reset
Hi, I had a number of wag102 access around my work which I didnt have passwords to. I did a factory reset successfully. The default password is 'password' and i can successfully connect to it via wi...
  • JohnC_V's avatar
    Aug 31, 2017
    Hi Mash123,
    Welcome to the community!
    It seems that you are going to start from the scratch here. Once you connect the AP to your PC, you may need to set a static IP on your PC within the range of the AP.
    Please set your PC to static IP: 192.168.0.200, 255.255.0.0, then try to ping the AP and check if it will respond.
ProSupport for Business
