LAN-Turtle
Feb 28, 2018Aspirant
cannot access router
I have a DELL T7910 workstation and a WAC730 connected via a GS108PEv3 to a modem. My problem, I just cannot access the WAC730. All LEDs are lit, the activity LED blinks, both the 2.4GHz and the 5G...
- Mar 02, 2018
you are right, 'access' is not the correct word, it should be 'login".
BUT: organizing more than 10 projects in parallel, I got totally confused, could not think strait and panict. That was when I submitted this problem. This morning, at 03:00 AM, I rose from bed and did a well defined, step by step installation.
- Installed an IP-monitor and located the WAC
- logged in successfully and configured it.
-> now everything works and my problem is solved.
I am very sorry for waisting your time with my panic and thank you for putting me back into line.
michaelkenward
Mar 01, 2018Guru - Experienced User
You have a modem, a wireless access point and a switch. (What's the modem?)
The switch should come after the modem. Is that how it is organised at our end? And where is the access point ?
Is your question about the switch? If so, this is the wrong place. This is for WiFi RoutersWiFi Routers.
Switches appear here:
Switches - NETGEAR Communities
Maybe you want to know about the access point. In which case, try here:
Business Wireless - NETGEAR Communities
