johany
Apr 06, 2017Aspirant
Cannot change radio settings in Business Central 2.0
Hello, I have around 10 WNDAP350 connected to Business Central 2.0, all of them using software version 3.5.6.0. The problem I'm having is that I can't change any radio settings. If I try to chan...
- Apr 10, 2017
I updated the firmware to the latest version on all devices and now I can change radio settings again.
johany
Apr 10, 2017Aspirant
- DaneAApr 11, 2017NETGEAR Employee Retired
I'm glad to know that updating the firmware has resolved the problem. :)
Since you got your concern resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Welcome tot he community! :)
Cheers,DaneA
NETGEAR Community Team
