Scirocco16V
Sep 30, 2016Guide
Can't reach web portal
I just took a new WAC720 out of the box, plugged it in, and tried to access the management interface. Chrome says: "This site can’t be reached. The webpage at https://192.168.7.30/ might be temporari...
- Oct 03, 2016
I finally got into it. I got a laptop and connected it directly to the AP with cat5 & set the laptop's IP to be on 192.168.0.x. Then the web portal loaded without problems. The AP had the 3.1.1.0 firmware. I updated the firmware to the newest, configured it with static IPs, and it seems to be working fine now.
Only 2 complaints:
1) You have to be the same subnet to access the management interface. I have it in 192.168.9.x & would like to be able to manage it from 192.168.7.x.
2) The NTP client doesn't like using Windows Servers as time sources; the date changed to something in May & when I use the default netgear NTP it doesn't recognize daylight savings time.
Scirocco16V
Sep 30, 2016Guide
Chrome 53.0.2785.116 m
IE 11.589.10586.0 Update Versions 11.0.35 - I get the "There is a problem with this website's security certificate" page, I click to continue to the website, then get "This page can't be displayed".
Firefox 33.1.1 - error: "Unable to connect - Firefox can't establish a connection to the server."
I am able to connect and login using putty & SSH, but I don't know how to do anything with it through the CLI.
nmhTester
Sep 30, 2016NETGEAR Employee Retired
on ssh, you run commands like
get system
get management
get interface
top
ps
We will know what image is running on your AP.
- Scirocco16VOct 03, 2016Guide
Only 2 complaints:
- RaghuHROct 05, 2016NETGEAR Expert
Hi Scirocco16V
Could you please share your network drawing for the complaint 1.
Could you please share details Windows Servers for complaint 2
Please share AP config as well.
Thanks
- Scirocco16VOct 10, 2016Guide
Both complaints have been resolved.
Kaspersky Endpoint Security was blocking the web interface for some reason. When I added the WAP's IP to KES's trusted list, it loaded fine from different subnets.
The time seems to be updating correctly from the Windows Server also now. Not sure what changed there, but it's working.
Thanks for the responces.
