Azurelink
Sep 22, 2021Star
Changing to a new Network Procedure - Airbridge WBC502B2
I am having problems switching my Insight Instant Airbridge from one Comcast Xfinity Cable connection to another Internet-only router (Comcast Business). The cable modem and router are Xfinity-comp...
Sep 23, 2021Guru - Experienced User
What was the "old router"?
What new setup (device models) did xfinity set you up with for the business plan?
- AzurelinkSep 23, 2021Star
Hi Plemans
The old cable modem/router is an ARRIS TG1682G provided by Comcast which I've had for maybe 8 years. I think it's DOCSIS 3.0.
The new modem and router which I bought myself are:Cable Modem: Motorola MC8600 DOCSIS 3.1
Router: Motorola AC2600 4X4 WiFi Smarte Gigabit Router with extended range, Model MR2600.
- plemansSep 23, 2021Guru - Experienced User
Both are solid devices.
did you try factory resetting both airbridges and try reinstalling them?
