Azurelink
Sep 22, 2021Star
Changing to a new Network Procedure - Airbridge WBC502B2
I am having problems switching my Insight Instant Airbridge from one Comcast Xfinity Cable connection to another Internet-only router (Comcast Business). The cable modem and router are Xfinity-comp...
Sep 23, 2021Guru - Experienced User
What was the "old router"?
What new setup (device models) did xfinity set you up with for the business plan?
Azurelink
Sep 23, 2021Star
Hi Plemans
The old cable modem/router is an ARRIS TG1682G provided by Comcast which I've had for maybe 8 years. I think it's DOCSIS 3.0.
The new modem and router which I bought myself are:
Cable Modem: Motorola MC8600 DOCSIS 3.1
Router: Motorola AC2600 4X4 WiFi Smarte Gigabit Router with extended range, Model MR2600.
- plemansSep 23, 2021Guru - Experienced User
Both are solid devices.
did you try factory resetting both airbridges and try reinstalling them?
