Arcesilaus
Apr 10, 2016Aspirant
Dynamic VLAN assignment using WC7520 controller
Hi, I've been using a few WNDAP360 AP's for a while and consider adding a WC7520 controller. However, I would like to use dynamic VLAN assignment using a RADIUS server. Whereas this is poss...
- Apr 18, 2016
Hi
Thanks for your help!
After reading the articles you suggested, I was still unable to find a definite answer, so I asked the pre-sales support and got quickly the following answer from Level 2 Tech Support:
There was a feature request to ask to implement this, however it looks like it will not be implemented for the WC7520. There is also a feature request for the WC7600 which does look more promising, but still not possible currently and is not guaranteed to be implemented.
In short: No, it isn't possible, won't be on the WC7520, and might become so on the WC7600.Too bad, and it makes the WC7520 much less interesting for me, but at least this has been made clear quickly.
Arcesilaus
Apr 18, 2016Aspirant
Hi
DaneA
Apr 18, 2016NETGEAR Employee Retired
Hi Arcesilaus,
I appreciate that you have shared this relevant information here in the community. :) This will serve as reference to other forum users.
Cheers,
DaneA
NETGEAR Community Team
