Alith7's avatar
Alith7
Firmware update failed!
I have two units.  One upgraded to 2.1.12 and then 3.5.5.0 with no problems.
the other, after the 2.1.12 upgrade would not accept my username and password, I tried the default too, nothing worked.  it was still coming up on the static IP assigned to it, but I could NOT log in.
so I tried factory reset, hold in the reset, power on, hold for 5 seconds, etc.
on my main router, I can see 192.168.0.100 is connected to the router.  but I can not get it to load on any browser, on any computer.  I even tried connecting it directly to an isolated PC, doing the reset, and nothing.  PINGing the IP returns unvavailable.
Any ideas?
  • Support was very helpful actually, went through what I had already done to troubleshoot and determined the unit was defective.  Have lifetime replacement, so they are sending out a new one.
    Thank you for the help!
  • thcheng's avatar
    thcheng
    NETGEAR Expert
    Hi,
    In the case of connecting to a PC isolated from the network, can you ping the AP?  Try the default IP address of 192.168.0.100, after you hit the reset button for 8 to 10 seconds.
    Thomas
    • Alith7's avatar
      Alith7
      I tried that too.
      it says it unreachable.
      it is sending out the default Wifi signal too.  but connecting to that does the same thing.
      • Alith7's avatar
        Alith7
ProSupport for Business
