Coffee-man's avatar
Coffee-man
frequent disconnects
Hello and thank you for your help!    I have two R7000 rounters connected to the same modem. I have created two different networks, becouse I want some of the devices to be on its own network and s...
  • schumaku's avatar
    schumaku
    Oct 14, 2020
    Using a passthrough-network cascading - not the ideal solution of course.
    Introduce a router able to handle two or more networks, on tagged VLAN or untagged dedicated VLAN ports, which can do the NATing accordingly onto one public IP. Something like a Netgear BR200 with dedicated unmanaged switches or switches allowing to configure multiple VLANs, like the Smart Managed Plus units. The R7000/R7000P can be given a second life (I hope) as wireless access points.
ProSupport for Business
