Coffee-man
Oct 14, 2020Aspirant
frequent disconnects
Hello and thank you for your help! I have two R7000 rounters connected to the same modem. I have created two different networks, becouse I want some of the devices to be on its own network and s...
- Oct 14, 2020
Using a passthrough-network cascading - not the ideal solution of course.
Introduce a router able to handle two or more networks, on tagged VLAN or untagged dedicated VLAN ports, which can do the NATing accordingly onto one public IP. Something like a Netgear BR200 with dedicated unmanaged switches or switches allowing to configure multiple VLANs, like the Smart Managed Plus units. The R7000/R7000P can be given a second life (I hope) as wireless access points.
schumaku
Oct 14, 2020Guru - Experienced User
That would be the cascade - however for your PoS systems (credit card processing I guess) there is pass-though traffic for the other - so either the PoS traffic on the inner network does flow through the outer network, or the guest network on the inner does go thourgh the PoS network. Both solutions are probably not what a PoS validation would accept.
Coffee-man
Thank you! I attempted cascade, and everything seem to be working, but now my POS router is just a part of the rest of the network and is connected to all of the devices on my network - so I'm worried about the security.
Let's say I got BR200 - is that something a sami tech savy user be able to configure, or would it require me hiring a professional anyway?
