mmassee
Apr 06, 2016Aspirant
FVS318N router keeps dropping connectivity
Hi all - I have posted this problem in the past. As usual. The problem clears up for several months and then comes back. This is with my FVS318N router. Since yesterday, I have been losing all connec...
- Apr 10, 2016
Thanks again for the replies. Having to power cycle the router is my challenge. When the problem occurs, the only way I can get acces back is to power cycle so I would not be able to get the data from the syslog. I was not happy support could not give me an ETA as to when an advance person could log into my router to see if they could uncover something, but I realize support teams are busy. I am accepting one more RMA and keeping my fingers crossed I will finally get a router that is reliable. As a side note, my Cisco router has been online for about 5 days now so I am confident the problem is with the Netgear router. Unfortunately my confidence is not there with Netgear any longer but am willing to try one more router
DaneA
Apr 10, 2016NETGEAR Employee Retired
Hi mmassee,
I am not sure if the syslogs will be able to also debug that you have performed a power reset on the FVS318N. However, the dropping of connection will be captured by the syslogs by the time it occurs.
For me, I think there should be an ETA as to when the engineering team should have remotely logged-in to check your FVS318N since the issue happened several times and it should be given priority because it has been replaced a couple of times already.
DaneA
NETGEAR Community Team
mmassee
Apr 10, 2016Aspirant
