SistemasSR
Sep 10, 2015Tutor
Hey there, Error on my wnap210 at office while upgrading
Well, I saw in the website that you got the new firmware version for wnap 210, 2.1.6 on website. I downloaded it, and while trying to upgrade I received the next message. There was an error upg...
- Sep 14, 2015
Hi SistemasSR,
SistemasSR wrote:
a. Excuse me but, where can I see it's version? Im looking for it and doesnt appear.
You may check the version by checking the serial number prefix of the WNAP210:
Serial number prefix for v1: 220
Serial number prefix for v2: 3FB
SistemasSR wrote:
More info: I tried to update from 2.1.4 to 2.1.6, and I just saw on website that there is a 2.1.5 available. Does it matter?
Both WNAP210v1 and WNAP210v2 has firmware version 2.1.5 so it would be best to check which version you have. The firmware version for the WNAP210v1 might not be compatible with WNAP210v2 and vice versa. Check these links below where to download the approriate firmware:
http://downloadcenter.netgear.com/en/product/WNAP210#searchResults - WNAP210v1
http://downloadcenter.netgear.com/en/product/WNAP210v2#searchResults - WNAP210v2
DaneA
Netgear Community Team
DaneA
Sep 13, 2015NETGEAR Employee Retired
Hi SistemasSR,
A few questions below:
a. Is your WNAP210 a v1 or v2? (v = version)
b. Did you perform the firmware upgrade via wired connection or wireless connection through the WNAP210?
c. After downloading the firmware, did you unzip it before you proceed with the firmware upgrade?
I look forward to your response. Welcome to the community! :smileyhappy:
DaneA
- SistemasSRSep 14, 2015Tutor
Hi there,
b. Wired
c. Yes I did Unzip before
Thx :)
- DaneASep 14, 2015NETGEAR Employee Retired
Hi SistemasSR,
DaneA
- SistemasSRSep 15, 2015Tutor
Thank you, those links gave me no error.
see ya :)
