Glenikins
Jan 03, 2018Aspirant
How to access web interface on WAG102 with a modern browser
I am unable to open the web interface on our WAG102 access point. I've tried Microsoft Edge, IE11, Chrome and FIrefox. All report similar errors, associated with SSL/TLS. Is there any way that I can ...
- Feb 07, 2019
I needed to reset some things on several WAG102s we have. The answer was to download and install Virtualbox (you could use another if you wanted) then go to
https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
and download a virtual machine with IE8.
It was fairly easy to get running and easily connects to the WAG102 interface.
antinode
Jan 03, 2018Guru
> [...] All report similar errors, [...]
And, with my weak psychic powers, I can't see any of them. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
If all you're seeing is a complaint about sending some user
credentials over an unencrypted/insecure link ("http://" instead of
"https://"), then the easy thing to do is ignore the warning, and
proceed. Presumably, you're talking to your own gizmo on your own LAN.
If someone can overlisten to that traffic, then you're already in big
trouble.
