Glenikins
Jan 03, 2018Aspirant
How to access web interface on WAG102 with a modern browser
I am unable to open the web interface on our WAG102 access point. I've tried Microsoft Edge, IE11, Chrome and FIrefox. All report similar errors, associated with SSL/TLS. Is there any way that I can ...
- Feb 07, 2019
I needed to reset some things on several WAG102s we have. The answer was to download and install Virtualbox (you could use another if you wanted) then go to
https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/
and download a virtual machine with IE8.
It was fairly easy to get running and easily connects to the WAG102 interface.
Zirax
Jul 20, 2022Aspirant
Adding to this conversation very late but from my research edge, chrome and firefox cannot access the config page. I have tried to disable everything about the https check but the actual issue is that there is literally no certificate (tested using openssl on opensuse leap). This means that no browser will allow you to access it, the security check fails before everything that you can choose to ignore. All of this despite the access point itself redirecting to https, not the browser. Ironic to me that this was marketed as a professional product, thank you for the solution.
