eshonbela
Sep 22, 2023Follower
How to add 2 WAX630E AP's to my Network
I have the CR1000A Router with 1 gig fios internet service. I want to use just my two Netgear Access Points this way I can have seamless transitions between the access points (1 upstairs and 1 down...
schumaku
Sep 22, 2023Guru - Experienced User
Not at all, the router does continue doing the NAT for your LAN IP subnet.
Connect both WAX630E to your router LAN, configure the same SSID, same security (WPA2-PSK due to limitations of WPA3!). This is all you have to do.
schumaku
Granted, no WPA2 on the 6 GHz band - so you need to deploy a dedicated network there.
