Kune69100
Jan 29, 2022Tutor
IPTV Behind WAX204
Hi, I wanted to upgrade my WIFI to WIFI 6, replacing a WAC104 by a WAX204. The probleme is, my IPTV box behind the router does'nt work anymore with WAX204. I'm using the WAX204 in AP mode, n...
michaelkenward
Jan 29, 2022Guru - Experienced User
Neither of those is one of the devices covered i this section for General WiFi Routers (Non-Nighthawk and Non-Orbi).
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge, especially "business" products.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Kune69100
Feb 02, 2022Tutor
Hi,
From Netgear FR, I tried in router mode to set a Bridge VLAN, it works in router MODE but is broken when switching back to AP MODE.
I will stay in router MODE + VLAN bridge on all LAN port + WIFI 1.
