bulnomali
Jan 25, 2023Follower
Is wi-fi 6 worth it over wi-fi 5?
Right now I'm looking at accespoints after getting a switch (supporting PoE+), mainly the TP-Link Omada EAP245 and the Netgear WAX214, the netgear supporting wi-fi 6 at 1.200Mbits on the 5Ghz band wh...
Jan 26, 2023Guru - Experienced User
If you're doing it mainly for your occulus go with the wifi 6. The occulus supports wifi 6 and will have a better connection.
