RudyTwee
Jan 25, 2022Follower
Netgear Insight wifi roaming
Hi,
I have a wireless network with 4 WAC720 antennas. Now there are some problems with the roaming thru my office cause of sticky Wi-Fi.
I know I could solve this with a wireless controller like the WC7520 where I can set forced roaming, but that seems a bit overkill to just solve this problem.
Now my question: Is it possible to manage forced roaming settings without a physical controller, but with a software or cloud-solution? Maybe with Netgear Insight Pro? I can’t find this specific information anywhere.
Thanks for any clear answer!
Hi RudyTwee,
Welcome to our community! :)
WAC720 is one of our old access points that does not support roaming feature unless it is connected to a wireless controller. This also does not support Insight Feature but our newer models thus support Insight and roaming feature as well.
John
NETGEAR Community Team
1 Reply
- JohnC_VNETGEAR Employee Retired
Hi RudyTwee,
John
