ryoussefi
Nov 30, 2022Guide
Netgear WAX214 Speed Issue
Hello - I installed a Netgear WAX214 access point on my existing Xfinity home network. I want to leverage the access point as a different wifi network to support cameras, but I am having major speed ...
Dec 04, 2022Guru - Experienced User
I'm a bit surprised its locked on channel 12. What region are you in? Xfinity is a US based company and in the US, its only channels 1-11 that are allowed. So I'm a bit more curious about your region or whats going on what that xfinity router/modem.
ryoussefi
Dec 10, 2022Guide
For some reason on another screen, the Xfinity router channel was showing correctly as 11. I have disabled the channels on the access point to avoid interference with the Xfinity gateway, this has seemed to have helped.
