shubhadeepb
Nov 30, 2016Tutor
NETGEAR Wifi router with Bridge Mode Support
In our office, we are using DSL broadband for Internet. We have a ADSL modem (provided by the Internet Provider), where the input DSL connects. Then we connect the output of the ADSL modem with a NET...
- Dec 05, 2016
Hi shubhadeepb,
The FVS114 does not support VLAN and I believe the 24-port switch is just using the default VLAN in the diagram you posted. Regarding this, the laptop that is wirelessly connected to the WAC730 and the network printer are both in the same network and they will have connectivity to each other.
Regards,DaneA
NETGEAR Community Team
DaneA
Dec 01, 2016NETGEAR Employee Retired
Hi shubhadeepb,
Welcome to the community! :)
For me, its more applicable to use an access point than a wireless router. If you will connect a wireless router to the FVS114, that will result into a Double NAT scenario. I suggest the diagram below:
I recommend the WAC730 access point. It supports Wireless Distribution System (WDS) in which you may set it up either point-to-point or point-to-multipoint wireless bridging. Check the WAC730 data sheet here for more details.
DaneA
- shubhadeepbDec 04, 2016Tutor
DaneA, Thanks for your response. This community is really great. :)
I have only one confusion. Let's consider the following diagram,
I want to access the Network Printer (connected with the 24 Port Switch) from the Laptop (connected to the WAC730). WIll it be possible in your mentioned scenario?
- nmhTesterDec 07, 2016NETGEAR Employee Retired
Please remember to mount the Access point in a way that gives best coverage for the area,
WAC730 is designed for wall mount or ceiling mount, but you can put it on desk also. the radition patterm will be facing the white dome.
https://www.youtube.com/watch?v=VjvN_GKXlZw
https://www.youtube.com/watch?v=SJ8vMe1BCoc
