shubhadeepb
Nov 30, 2016Tutor
NETGEAR Wifi router with Bridge Mode Support
In our office, we are using DSL broadband for Internet. We have a ADSL modem (provided by the Internet Provider), where the input DSL connects. Then we connect the output of the ADSL modem with a NET...
- Dec 05, 2016
Hi shubhadeepb,
The FVS114 does not support VLAN and I believe the 24-port switch is just using the default VLAN in the diagram you posted. Regarding this, the laptop that is wirelessly connected to the WAC730 and the network printer are both in the same network and they will have connectivity to each other.
Regards,DaneA
NETGEAR Community Team
shubhadeepb
Dec 04, 2016Tutor
Hi DaneA,
Aplogy for replying late. I have one more query, asked as the reply of your solution.
Thanks a lot for your support.
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi shubhadeepb,
DaneA
- shubhadeepbDec 05, 2016Tutor
Thank you! I have accepted your answer as the solution :)
- DaneADec 05, 2016NETGEAR Employee Retired
Hi shubhadeepb,
You're welcome! :) Feel free to post your future concerns here in the community.
Cheers,
DaneA
