Murrayfield's avatar
Mar 09, 2017
Pro Safe Wireless Access Point WN370
I have purchased four of these Wireless Access Points without realising that I require to purchase a controller to manage these thinking they were stand alone devices.  What is the most inexpensive controller I require to purchase to make these things work.  The WC7600 is far to powerfull for what I require.  What are my options please.
  • Hi,
    Just for the clarify the WN370 can be managed by WC7600, WC9500, WC7600v2, WC7500 controllers.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Murrayfield,
    Welcome to the community! :)
    I'm afraid to inform you that the WN730 can only be managed by the WC7600 wireless controller.  Since you need a standalone access point, I suggest the WAC510 access point.  Kindly check its specification and comparison with other NETGEAR access points on the data sheet here.
    DaneA
    NETGEAR Community Team
    • Hi DaneA
      Thanks for the info.  I did a bit more research in between posting the question and receiving your reply and I have a query.  One of the documents I searched on came up with the following (page 2)  https://www.netgear.com/images/pdf/WC7500_DS_30Mar16.pdf which seems to show support for the WN370 by the WC7500.  Well I hope so 'cos I have bought one ;-)
      Cheers
      Ian
    • DaneA's avatar
      DaneA
      Murrayfield,
      Yes, the WC7500 also supports the WN370.  From my previous response to you, I have based my answer on page 1 of the WN370 installation guide here where it says "The WN370 access point can only be deployed in a network managed by a ProSAFE WC7600 wireless controller" under the section of 'Set Up the Access Point.'
      DaneA
      • LaxmankumarG's avatar
        LaxmankumarG
        NETGEAR Expert
        Hi,
  • Hi
    I can categorically say that the wc7500 will manage the wn370 I managed to get four working today. The first two were easy but the second two were a problem. In the end I rebooted the wc7500 then plugged in each AP individually factory reset the AP found it on the controller then edited the AP and the WC to fit into my network op address scheme. Worked a treat
    • mmosegui's avatar
      mmosegui
      I just have bought THREE wn370 to realize that I need to buy also a @#!? additional "machine" to have them configured. Is there any other mean to configure them? telnet? https? ftp?. When they first are powered I presume they send a DHCP discover and "WireSharking" the communications (yes, I have a primitive HUB not SWITCH that can propagate packets) so I could know their IPs. No chance?
        LaxmankumarG
        NETGEAR Expert
        Hi,
        WN370 can only be managed and configured by the following WLAN controllers.
        WC7500, WC7600, WC7600v2, WC9500. You have to buy one of these controllers to make WN370 work, and there is no other option to configure it.
ProSupport for Business
