stewcoarchives
Oct 05, 2023Aspirant
New WAX610 - Internet connectivity for laptops but not smartphones
I just installed a WAX610, hardwired to a nearby, new Netgear GS308E switch in a new office. The switch connects to the building's router, somewhere in the building. The AP has Internet connectivit...
- Aug 06, 2024
Final Update 6 Aug 2024:
The experiment to change my WAX610 from Bridge mode to NAT mode was very brief. Although smartphones finally gained Internet connectivity, the bandwidth was excruciatingly slow so as to be unusable.
Down here in the basement where all of this has been happening, the adjacent office requested the IT folks upstairs to install WiFi for them (probably since mine was unusable to smartphones). Their new WiFi antenna (I've never seen it) provides quick, reliable connectivity both to our PCs that have never had a problem, as well as our smartphones which always had a problem with the WAX610.
I have decommissioned the WAX610.
schumaku
Apr 29, 2024Guru - Experienced User
The NAT-mode-SSID does not make a difference or fix anything magically for users experiencing the "Connected / No Internet Access" on recent Android devices.
hnagaraju
Apr 29, 2024NETGEAR Expert
Current topology:
Router(DHCP server)====L2 Poe Switch====AP ~~~~wireless clients
Normal Open SSID.
The issue is that some clients get IP addresses, and others do not.
We can rule out any issues on the DHCP server by moving the DHCP server to AP.
Let try this :
Router(DHCP server)====L2 Poe Switch====AP (DHCP server) ~~~~wireless clients.
Normal Open SSID. Now, the AP gives out the IP address.
Another suspect: Is there any Captive portal enabled on the SSID?
If so, you get the mobile phones to pop up the captive portal splash page,
open the browser on the phone and type http://www.msn.com
(note http:// and not https://)
Please open a support case via chat if none of these helped.
NETGEAR can help you better by looking at network topology and AP configuration files.
- schumakuApr 29, 2024Guru - Experienced User
hnagaraju wrote:
Let try this :
Not sure what hnagaraju expects from letting the OP try http ... considering msn.com does almost certainly force a https redirect (https and localized site) anyway?
Much better would be using http://neverssl.com/
- stewcoarchivesMay 07, 2024Aspirant
It's not accurate that only some clients get an IP address. All clients can successfully authenticate to the WAX610, using the open SSID, and all receive an IP address from the router. I can see the devices connected to the SSID and can see them in the router's device table with their assigned IP address. But for some reason, smartphones get 'Internet not available' errors upon authenticating to the WAX610 and getting their IP address from the router.
I was out-of-office last week, but before I left I logged into the router (not the WAX610) and assigned a reserved IP address to the physical MAC address of my smartphone. (A previous commenter erroneously stated that I had no access to the router, despite my having stated that I did have remote access but no physical access). I then configured that same IP in my phone's saved WiFi connection to the open SSID on the WAX610.
Upon arrival in the office today, my smartphone connected automatically, as usual, but this time it also had Internet service, which is a first.
If this workaround turns out to be repeatable, I'm OK with reserving IP addresses for the smartphones of the people who work here in the office. Our visitors typically rely on our WiFi only for their laptops, and that connectivity has always worked from the time that the WAX610 was installed.
- stewcoarchivesMay 21, 2024Aspirant
Today's experiment was to change the WAX610 AP from Bridge mode to NAT mode, so that the WAX610 would issue IP addresses instead of the upstream router.
After changing to NAT mode, my Android smartphone connected to the SSID on the WAX610, received a private IP from the WAX610, and had Internet connectivity right away. This is the best result thus far - open connectivity for smartphones without that annoying "Internet not connected" error.
- stewcoarchivesAug 06, 2024Aspirant
