nkstjp
Jul 15, 2026Aspirant
WAX610-100JPS VLAN設定(Untagged/Tagged)について / VLAN Untagged/Tagged setting on wired port
Japanese --- お世話になっております。 弊社にてNETGEAR WAX610-100JPSの導入を検討しており、ユーザーズマニュアル記載の仕様について1点確認させてください。 構成イメージは以下の通りです。 ・WAX610をブリッジモード(NATモード無効、初期設定のまま)で使用 ・SSID1にVLAN ID 1(初期値)を割り当て ・SSID2に別のV...
- Jul 17, 2026
nkstjp wrote:
The intended configuration is as follows:
WAX610 used in Bridge mode (NAT mode disabled, default settings)
- SSID1 assigned VLAN ID 1 (default)
- SSID2 assigned a different VLAN ID (e.g., VLAN 20)
- Connected to an upstream router via a single LAN cable, with the upstream router separating segments per VLANDefinitively possible, yes.
nkstjp wrote:
Regarding the "Untagged VLAN" checkbox described on pages 151-152 of the User Manual, I understand this to be a single setting that applies to the entire wired (Ethernet) interface. If this setting is left as "Untagged VLAN" (default, VLAN ID 1), which of the following behaviors occurs?
(A) Frames belonging to the SSID on the native VLAN (VLAN 1 in this case) are sent untagged, while frames from SSIDs assigned other VLAN IDs (e.g., VLAN 20) are automatically tagged and sent out simultaneously from the same wired port (i.e., behavior similar to an 802.1Q trunk port).Correct: Confirmed, your understanding is correct!
Native VLAN is an outated Cisco (plus some other vendor) designation from the past, modern switches no longer have such a potentially cumbersome default native VLAN anymore.
You have to configure an Access Port for [U]ntagged VLAN 1, and don't forget to set the port to PVID 1, so untagged ingress frames will be assigned to the switch VLAN ID 1.
Inkstjp wrote:
If behavior (A) is confirmed, we believe it would be possible to pass traffic from both SSID1 (VLAN1) and SSID2 (VLAN20) to the upstream router over a single LAN cable, with access control per VLAN handled on the upstream router side.
Exactly, thats the way it is.
schumaku
Jul 17, 2026Guru - Experienced User
nkstjp wrote:The intended configuration is as follows:
nkstjp wrote:Regarding the "Untagged VLAN" checkbox described on pages 151-152 of the User Manual, I understand this to be a single setting that applies to the entire wired (Ethernet) interface. If this setting is left as "Untagged VLAN" (default, VLAN ID 1), which of the following behaviors occurs?
Inkstjp wrote:If behavior (A) is confirmed, we believe it would be possible to pass traffic from both SSID1 (VLAN1) and SSID2 (VLAN20) to the upstream router over a single LAN cable, with access control per VLAN handled on the upstream router side.
