Germain1's avatar
Germain1
Restrited access, and no access to internet
When i connect home my new computer, it sees all the nearby wifi and i can connect with my wifi. When I get to the office as I open the computer, it sees the wifi and our netgear wifi. As I log to our wifi, after a time, it becomes limited or restrited, and then I have no longer access to internet. What can cause that it. After that, I do not see any other nearby wifi either.
  • I have updated the LAN driver and it solved the problem as you suggested.
    Tthank you
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Germain1,
    Welcome to the community! :)
    Kindly answer the questions below:
    a. Do you have a NETGEAR device at your home and at your office?  If yes, what is the model and current firmware version of it?
    b. Have you tried to update the software driver of your wireless LAN adapter on computer/s?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
    Tthank you
ProSupport for Business
