scliffe
Sep 22, 2016Aspirant
SNMP wlan utilization rate
I'm trying to understand the hrSysWlanUtilizationRate SNMP object. The description in the MIB file says "the field indicates the wlan Utilization Rate based on
calculating station access Time" so I would expect it to vary quite a bit but when I graph it it looks like this:
This is not what I expected so can anyone explain what this field actually is?
Thanks,
Steve.
Hi scliffe
We found issue in the driver code and patch is available. Please contact Netgear Support Engineer to get the patch.
Thanks
Raghu
- thchengNETGEAR Expert
Hi,
Are you using the WAC720 as a standalone or controller mode?
Thanks,
Thomas
- scliffeAspirant
No - it's a standalone WNAP320 on the latest firmware.
- kohdeeAdministrator
Just curious, is that correlating with your AP's uptime?
- scliffeAspirant
A good suggestion, but no. My AP has been up for almost a week and this is occuring regularly 2-3 times/day:
[UDP: [192.168.128.254]:161->[0.0.0.0]:42517]=>[Linux wlan-ap 2.6.23-WNAP320_V3.5.6.0-g0c2ca724 #1 Tue Apr 12 03:19:54 PDT 2016 mips] Up: 6 days, 17:57:42.78
- RaghuHRNETGEAR Expert
Can you please tell me the application name that you are running to measure WLAN utilization?
When AP fails to fetch values from database this can happen.
