ScoobyDoo27
Jul 23, 2024Aspirant
Terrible speeds with WAX615 lately
I have 2 WAX615's running the latest firmware (10.8.6.3); one in my basement and one on my main level. Up until the last couple weeks everything seemed to be working fine. Now, I can barely pull 10 M...
schumaku
Jul 28, 2024Guru - Experienced User
More than a little bit thin, a lot of variables. What throughput you get when doing the Speedtest using the wired network and router to the Internet, using the Ookla?
- ScoobyDoo27Jul 28, 2024Aspirant
When hardwired, I am pulling around 900Mbps.
I didn't give much info because I'm not sure what info to give. There are so many settings and things I can change and I have no idea what I should change. I did change the power settings of my basement AP to the lowest possible to basically force my upstairs AP to be the primary one. It seemed to help a bit with my wireless speeds. Should I be using mesh mode or AP mode? Should I mess with any other settings?
