Marko156's avatar
Marko156
Turn Radio on button grayed out after upgrade to 3.7.7.0
I've just completed a 3-step firmware upgrade from v2.0.1 to 3.7.7.0 on my WNDAP350 AP.  After reconfiguring from default settings, I am unable to turn off the 2.4Ghz radio. In the wireless settings, the Wireless on-off status is on, and the Turn Radio On button is grayed out. I want to broadcast over 802.11an only.
I have tried IE10,Chrome, & Firefox v56.0 with no improvement.
I am also having trouble with my clients connecting.  These are fixed clients, that were operating without issue on the older firmware v2.0.1. The wireless clients don't connect at 802.11an speeds. after the clients are rebooted. It takes some reconfiguration on the Netgear Wnda3100 v2 USB WiFi adapter to make it work on 11an, but then will not reconnect at all after rebooting a client PC.
I have about 30 remote sites that require the upgrade to prevent a KRACK hack incident.
Any help would be greatly appreciated.
  • Wireless on-off feature is common for both 2.4 and 5GHz radio.
    When it is ON, we cannot make single radio to OFF.
    If you make  Wireless on-off schedule  is OFF then you should be able to disable radio.
    Thanks
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Have you tried Wireless on-off status OFF and see if you are able to disable radio?
    • Marko156's avatar
      Marko156
      I will be making a site visit this afternoon to attempt a resolution. The wireless on-off feature appears as a global command to turn on or off all radios.  It does'nt provide an option to turn off one or the other.  I'm a bit confused by this function.
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Thanks
        Raghu
ProSupport for Business
