THarlin's avatar
THarlin
Unable to update WAC720 firmware
Device is at firmware version 3.6.12, latest available is 3.8.3.  When I try to upgrade to that or other earlier versions I get "Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields."  Why?
  • Glad that you are able to figure out what the issue is. Please accept this as soultion if you are satisfied.
    Thanks,
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi Thomas Smith
    Welcome to the Netgear Community.  Could you please double check the following?  We would like to see what error you are seeing on the screen. Could you please paste the screen shot?
    Thanks,
    Raghu
    Upgrade Procedure:
    1. Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop.
      The Firmware File name after extracting is WAC720_WAC730_V3.8.3.0.tar
      Download Link: http://www.downloads.netgear.com/files/GDC/WAC720/WAC720_WAC730_V3.8.3.0.zip
    2. Login to the AP web interface.
    3. Select Maintenance > Upgrade > Firmware Upgrade
    4. Click the Browse button and locate the image (.tar) upgrade file.
    5. Click the Apply button to initiate the upgrade process.
      During the upgrade process, the wireless access point automatically restarts. The upgrade process typically takes several minutes. When the Test LED turns off, wait a few more seconds before doing anything with the wireless access point.
    • THarlin's avatar
      THarlin
      Thanks for the reply. But the error on my screen is exactly as stated in the original posting. If I were to take a screenshot it would add no additional information.
      • THarlin's avatar
        THarlin
        Also, perhaps I should mention that I have updated this unit's firmware successfully at least twice in the past.
ProSupport for Business
