coljediv
Dec 22, 2017Aspirant
WAC 510 - Clients Connect to Local Wifi But Not To Internet
I have been learning as I go with my two new WAC 510. At first I was using the Management Mode PC-Local Browser, with multiple SSID and was trying to use ACL, first by typing the allowed MAC and the...
- Dec 23, 2017
I solved the problem. The WAC510s are wired to an R8000 X6 router. The router has an access list. To reach the internet or probably anything else on the router, the client device needs to be in the router ACL. Since I am transitioning slowly from the router to the WAPs, I need to maintain both systems. Thanks for your help.
Retired_Member
Dec 23, 2017No, all the configuration including ACL settings would be lost when you move to Insight mode.
coljediv
Dec 23, 2017Aspirant
