n923157
Nov 05, 2021Follower
WAC 510 + C6300 Facebook wifi
I atttached my WAC510 to my home router Netgear Night Hawk AC1750, model R5700 and setup Facebook wifi and it worked as intended (choose WAC's SSID and got directed to page with options to login, Facebook login page or using passphase). I brought the WAC510 to our shop and connect to our modem/router Netgear C6300, hardware version V4.0, firmware version V2.01.26, had user connect to WAC's SSID but it asks for passphase without redirect to login options to Facebook login page as it does at home. My question to community is, is C6300 compatible with WAC510? What I need to do to get it working like it does at home?
1 Reply
- JeraldMNETGEAR Employee Retired
Welcome to the community!
It should work since both R6700 and C6300 function as routers.
Having that said, you can try performing a reboot or reset (if possible) on the WAC510 while connected to the C6300 to see if that resolves the issue.
Have you also tried connecting multiple devices to the WAC510 while it's wired to the C6300?
Regards,JeraldM
NETGEAR Community Team
