javier_perez
Nov 16, 2018Aspirant
WAC 720 hard RESET
Hello All
due to a posible loop error on the network (i dont sure about that yet), i lose contact with the WAC 720 in the configured IP, so i do hard reset to the device, connect through 192.168.0.100 and set the IP again, BUT OH! now the menu are only system and monitoring, and with very few config posibilities...
so two questions:
1 why?
2 can i restore a previous config via ssh? i dont see the CLI manual anywhere....
i assume is like config upload file://localhost/c/filename??? but how exactly?
regards
javier_perez Please select the check box cloud enabled to No and it will go for standalone mode after the reboot.
Then you can restore the config.
Thanks,
Raghu
- RaghuHRNETGEAR Expert
Thanks,
Raghu
- javier_perezAspirant
Thank you.....now all is working again!
