Retired_Member
Nov 18, 2017WAC104 GUI text file Update Fails
Hello,
I have the WAC104 – Dual Band 802.11ac Wireless Access Point, I have the latest firmware.
However, everytime I check for an update it gives the following.
| There is a new GUI text file available: | |
| Current GUI Language Version | V1.0.4.3 |
| New GUI Language Version | V1.0.4.9 |
| Do you want to download and use this new GUI text file? |
I click yes, and its says its updated, but then when I check for an update again, the same update is still available.
I have tried a factory reset, and installed the update manually, but it still says a GUI text file update is available.
Any help would be much appriecated.
Hi Liam Scorziello,
Could you please check now and see if you are seeing the same repetative message?
Thanks
Raghu
- RaghuHRNETGEAR Expert
Hi Liam Scorziello
We are checking this. We will update you here soon.
Thanks
Raghu
Hi Liam Scorziello,
Thanks
Raghu
- Retired_Member
Hi Raghu,
I have checked, and its no longer saying the GUI Update is available, thanks for your help, much appreciated.
Liam Scorziello
