TexARC
Nov 27, 2020Guide
WAC104 WPS button doesn't work?
TO provide my home with 2.4gHz access to my many legacy devices that I lost connectivity to when I upgraded to a Netgear Orbi 750, I bought a WAC104 online which arrived today. I also have two Negea...
schumaku
Nov 29, 2020Guru - Experienced User
Hi Ron,
Have no WAC104 at hand, in fact I had never used or deployed one of these.
TexARC wrote:When I boot the WAC104, all the the indicator icons flash during power-up. But the icon that should come on when the WPS is active(when I push the WPS button, in other words), it never lights up. I also cannot get either of the two mesh extenders to link to the WAC104. I think the button is not functioning, does NOT turn on the WPS function.
What was the out-of-the-box firmware? Have updated to the current one before the initial set-up and WPS attempts?
The WPS button itself (also reset or WiFi on/off) does just trigger an I/O port (hardware is reliable in general), the effective actions are pure software defined.
TexARC wrote:In the setup for the WAC104, there is a dropdown for "Setup" which contains two links: Wireless Setup and WPS Wizard.
The link to Wireless Setup works fine, but the link to "WPS Setup" does nothing.
Looking at the last two firmware update release notes https://kb.netgear.com/000061394/WAC104-Firmware-Version-1-0-4-12 (2019-11-11) and https://kb.netgear.com/000062303/WAC104-Firmware-Version-1-0-4-13 (2020-09-14) shows this
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
- When you unbox your AP, if the FW version is lower than V1.0.4.1, be sure to perform the following firmware update procedure before updating to V1.0.4.13.
- Back up the configuration file
- Do factory defaults after upgrade
- Clear your browser cache
- Enter the IP address to log in to the device's local browser user interface
- Restore the configuration file
- When firmware V1.0.4.1 is installed already, update to the latest FW. All settings will be retained properly after a successful update.
Oddly v1.0.4.1 is the official initial firmware, so the first production release - appears the boxes left the factory before the initial firmware was ready.
No word of a WPS button issue at all.
Time for an update and factory reset...
