a_p_s
Dec 30, 2017Aspirant
WAC120 - Unable to Edit Set-up
I've got a WAC120 AP that was set-up some time ago and I'd now like to tune the performance / edit security details. My issue is that I can log-on to the admin web-page, see the various tables, but am unable to edit the settings. The menu in, say, Wireless Setings are unresponsive with the page itself just having Cancel and Apply options but no Edit option. All this is using Edge on Windows 10. Any suggestions?
Hi a_p_s,
I suggest you the following below:
1. Use other browsers like Chrome or Firefox then check if you are able to edit the settings of the WAC120.
2. Use other PCs or laptops to access the web-GUI of the WAC120 then check if you are able to edit the settings of the WAC120.
3. If ever step 1 and 2 did not help, reset the WAC120 to factory default settings then reconfigure the settings from scratch.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi a_p_s,
DaneA
