dpasadis
Jun 01, 2021Tutor
WAC505: Apple clients (iPhones, Macbook Pros) won't connect with Private Addressing enabled
I can't connect Apple devices (iPhones, iPads and Macs) to my WAC505 that have Private Addressing enabled (randomized MAC addresses). I would like to configure my WAC505 to accept these connections. As a workaround, I can disable private addressing on iOS devices but I haven't found a way to do it on my Macs.
Any help would be greatly appreciated.
Thank you very much.
Unless you have configured some MAC security (random MAC os obviously prohibiting this idea), there is nothing related on these WAC. Possibly your router is out of DHCP pool, has MAC security in place, .... and won't accept these devices.
- dpasadisTutor
I should add....
The problem only occurs when adding a new device to the network. Devices added previously connect to the WiFI network just fine.
- dpasadisTutor
Thank you for your response. It's helpful.
Can I turn on some soft of logging to see why the WAC505 is rejecting a WiFi connection from one specific Macbook Pro? I know the password is correct.
