RobLigt
Dec 20, 2021Tutor
WAC510 - repurpose but still "locked" due to Insight registration?
Hi,
I was given a Netgear WAC510 which we really could use in our environment.
Unfortunately, it appears still to be a Netgear Insight's registered device and therefore can not be registered and not even reset?
I tried the reset as described in the manual but other then cycling of the various led-indicators, I can't see it appearing on our (wired) network?
I do notice that both wireless led's are turned off, so I gather the previous admin disabled the radios.
Is there truely nothing I can do with this WAC510 until the previous admin disassociates this WAC510 from their own Insight account?
As I expect that will never happen as that admin is no longer available.
Thus I can smash it to bits and return it to e-waste?
Thanks for any response!
This is intentional and by design. No local reset process does unbind it from Insight - for good reasons - think about....
THe LED behaviour can be part of the still active Insight config, e.g. LED all-off or LED only-power.
You can challenge a nice Netgear moderator to free-up the serial number/MAC address from the Insight binding. JohnC_V can you assist please?
- RobLigtTutor
schumaku
Thanks for the prompt response, much appreciated!
Whilst I can understand that a simple reset won't regain access(i.e. password-reset or something), but with a full/factory-default I would expect to get access to the WAC510.
As the latter should/would clear the complete configuration and thus pose no security-risks?
The WAV510 it is not, as far as I've understood it, a cloud-only device, but (also) locally managable?
We repurpose many Netgear kit, including some very expensive switches and this is the first time I can't get access to a Netgear product.
If it would be a cloud-only (read: Insight required) I can understand it to a certain extend, of course.
But most of the time, unless we purchase new kits, some admin left configurations/settings in the kit we repurpose.
I always will factory-reset, update the firmware and factory-reset again before deploying a kit into our network, as a standard practice.
I believe that a cloud-enabled product, like the WAC510, should offer the ability to factory-reset (and thus lose the complete configuration) eventhough it might be hooked into an existing Insight account as that way, whenever that decomissioned WAC510 is repurposed, it can be re-used again.
But that is my view of course, and I guess I'm wrong in this one.
@JohnC_V
if you can't help me please do let me know, I will then return the unit and get our money back.
I hate to give-up on any Netgear kit that could/should be re-used.
- YeZNETGEAR Expert
In most of the Insight-supported devices including WAC510, we have implemented in the firmware that if the unit is reset to factory default, it will be removed from the previously Insight account.
You can try again with this:
1. Make sure your WAC510 is connected to a router with Internet access, as the removal of Insight account association post factory reset will require Internet connection to make it effective.
2. Reset it to factory default one more time.
If this still does not remove it (the blue Cloud LED is still on after the 2nd factory reset), you can private message me the serial number of your WAC510, and I will help remove it.
Thank you.
- RobLigtTutor
Hi YeZ
Thank you for the response!
The firmware in this WAC510 might be quite old, I'm told.I went thru the reset-procedure (pressing the reset-button for 10 seconds) again, this time the power-led now shows solid orange (boot failed?), the Insight LED is flashimg green in almost some kind of morse-code:
From what I can see,5x then 3x, then 1x and then 2x?
I waited 10 minutes, no change in the led behavious as described, so I powered it off and reconnected the power, no chance.
Did I brick this WAC510?- schumakuGuru - Experienced User
Insight LED can be green (earlier serial numbers) or blue (later serial numbers).
Early firmware versions indeed were not able to "escape" from the Insight trap as I've mentioned before.
Amber power LED being on for a longer time indicates a boot issue - some kind of tftp recovery process might be required. Have no details at hand, but _assume_ the ubiquitous Netgear router tftp firmware recovery might be workable
Hi Rob,
Did you ever get it running? I have a WAC510 here too, also an early 4W8 model, and it is completely bricked. The power LED is orange and no matter what I do, nothing works.
For a while, this is formally possible: -> How do I remove a device from my Insight account?
Whatever 4W8 model means, the orange power LED tells us the bootloader is most likely bricked, the device can't boot successfully. Recovery using TFTP (like any Netgear router) -> How do I upload firmware to my NETGEAR router using a TFTP client on Microsoft Windows?
