Constantius's avatar
Constantius
Follower
Jan 27, 2018
WAC510 LAN Power
Currently have the WAC510 Access Point set up. The WAN ethernet is connect to my modem and is not using POE, so I had to plug the access point using the 12v adapter. My question though, is if I conne...
  • JohnC_V's avatar
    Feb 01, 2018
    Hi Constantius,
    Welcome to our community!
    WAC510 is a powered device. It does not provide any power to its port but it can receive power from a power source equipment.
ProSupport for Business
