Stephanfo's avatar
Stephanfo
WAC510 low coverage since last firmware 1.2.5.11
Hi All,
Since I updated the WAC510 with the last firmware (1.2.5.11), I noticed a big drop of the wifi coverage. Any advise before to try to return to the previous firmware to test ?
Regarding my tests, I was able to cover all my house, since the update, only 2 rooms. I also did external test, but after 25 meters, the wifi is low, and all attempts to connect fail. I tried with all my 5 devices (Apple only, I guess only 5ghz), same results.
I didn't change anything in the configuration between both firmware.
Thank you for your support.
Stef.
  • Hi Stephanfo,
    Welcome to the community! :)
    Did you perform a factory reset on the WAC510 after upgrading the firmware?  If not yet, I suggest you to perform a factory reset on the WAC510 then reconfigure it from scratch in order to start clean using the latest firmware version.
    Hope it helps.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Stephanfo,
    Hope it helps.
    DaneA
    • DaneA's avatar
      DaneA
      Stephanfo,
      I just want to follow-up on this.  We’d greatly appreciate your feedback.
      DaneA
      • Stephanfo's avatar
        Stephanfo
        Hi all,
        Yes, reset to defaults solved the problem. Thank all for your help.
        For the information, after factory reset, the RSSI Threshold is set to -85.
        Stéphane.
ProSupport for Business
