MrGralich
Nov 23, 2020Aspirant
WAC510 radio emission scheduler: need to downgrade firmware?
Hi there. I've purchased a WAC510 with the main purpose to schedule the wifi activity: on / off. I didn't do my homework right before purchasing, though, because now I understand that with the firmw...
schumaku
Nov 24, 2020Guru - Experienced User
MrGralich wrote:I'd need to actually turn radio off by schedule. Is it possible with this firmware? What if I schedule off all the SSIDs? Would the radio turn off?
What for a "need" exactly?
The current Insight Managed Smart Cloud Wireless Access Point WAC510 User Manual does show on p.4 that with it's publication revision 202-11840-05 from February 2019:
"We removed Set up a WiFi on/off schedule for the radios, which is replaced by Disable or enable a WiFi network or set up a WiFi activity schedule on page 54."
Try your luck to find the firmware which introduced this change late 2018/early 2019 under https://www.netgear.com/support/product/WAC510.aspx#download -> View previous versions ... review the downloads, check the release notes visible under the download, or try your best luck putting up older firmware.
Either way, with all SSID disabled (so no longer on air - not just "hidden") there won't be any announcement for any network on air. So why bother?
- MrGralichNov 24, 2020Aspirant
Hi schumaku and thanks for having taken the time to answer. My point is that I want the device to stop radio emissions in scheduled hours for health reasons, given the fact that I'll have a toddler in the premises in a short time :-)
But I don't want to switch the whole thing off by disconnecting the POE cable because I have another ethernet cable connected...
Once that I've possibly found the right firmware, do you see any harm in downgrading?
Or:
Would you advice to substitute this device with another Netgear access point with the precise feature I need? This WAC510 is probably an overkill for my other needs and I can still have a refund...
Thanks a lotMrG
- schumakuNov 24, 2020Guru - Experienced User
Toddler will request WiFi access soon - won't be that long. Issues will shift to a different topic soon.
What should the access point emit if there is no (or are no) SSIDs (BSSID) on air? It will not send "Hey here is your YXZ network", then "Hey here is your Guest network" into the air so no client will assign to it. It's a digital system, just sending if there is something to do...
