star0815
May 31, 2018Tutor
WAC510 sends packets to Port UDP 7788
Hi comminuty,
just discovered that my WAC510s are sending to 192.168.1.1:7788 UDP via eth0.
Port 7788 is not authorized to be used by IANA.
Can anyone please clarify?
Firmware V4.0.7....
- Jul 05, 2018
Hi star0815
This issue is addressed in the new firmware v4.2.0.11. Kindly follow the link to get new firmware.
https://kb.netgear.com/000059508/WAC505-WAC510-Firmware-Version-4-2-0-11
Thanks,
Raghu
DaneA
Jun 04, 2018NETGEAR Employee Retired
Hi star0815,
Let us try to upgrade the firmware to the latest version which is v4.2.0.9. You can download it here. Be sure to perform a factory reset on the WAC510 after upgrading the firmware then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, check if same concern will occur.
DaneA
NETGEAR Community Team
