star0815
May 31, 2018Tutor
WAC510 sends packets to Port UDP 7788
Hi comminuty,
just discovered that my WAC510s are sending to 192.168.1.1:7788 UDP via eth0.
Port 7788 is not authorized to be used by IANA.
Can anyone please clarify?
Firmware V4.0.7....
- Jul 05, 2018
Hi star0815
This issue is addressed in the new firmware v4.2.0.11. Kindly follow the link to get new firmware.
https://kb.netgear.com/000059508/WAC505-WAC510-Firmware-Version-4-2-0-11
Thanks,
Raghu
star0815
Jun 05, 2018Tutor
Hi DaneA,
have upgraded to latest firmware and performed a factory reset afterwards, then configured only neccesary settings (IP, password).
While no SSID is configured (or Day Zero configured one) no packets (7788/udp) are send out over eth0.
Packets are only sent when there is a configured SSID and clients are connected.
Will try some SSID-specific settings, but this config is used so far (default settings omitted):
IP LAN static (IP, Subnet, Gateway, DNS1+2)
NTP client=on, custom NTP server by hostname (and it is reachable)
Management mode=local (standalone)
UPnP=off
SSID "Guest":
Client Isolation=on
Band Steering=on
VLAN ID=99
802.11w (PMF)=on
One more thing: device is trying to query public NTP servers regardless of setting "use custom NTP server".
Best regards.
RaghuHR
Jun 05, 2018NETGEAR Expert
Hi star0815
Please download detailed logs from monitoring page and send it. BTW - Are there any chance that those wireless clients are used for any online gaming? Basically I would like to know what kind of traffic going?
Thanks,
Raghu
- star0815Jun 05, 2018Tutor
After some tests it looks like udp/7788 packets are only sent when there are two SSIDs configured. After removing second SSID there are no more packets in pcap. Also tried to have different configurations of first/second SSID.
So the config I just sent might not reproduce that behavior, just add a second SSID.
I have also seen my custom NTP server is not responding to device, so querying other NTP servers should be OK despite "use custom NTP server" is checked?
Thanks a lot!
Edit: Just verified, when adding a second SSID (all default values) it starts to send udp/7788 packets.
