NickHW
Jun 05, 2017Aspirant
WAC510 SSID to VLAN association
I read the manual for the WAC510 online and I'm not entirely clear on this point.
Does this model permit the creation of virtual access points which map to separate tagged 802.11Q VLANs at the Ethernet interface?
The comment in the manual "This VLAN ID is not the same as the 802.1Q VLAN ID that is used for the wired network" has me very confused.
Hi Nick
Yes you can have separate VLANs for different SSIDs. Let me know if you have any further questions on this
Thanks
Raghu
- RaghuHRNETGEAR Expert
Hi Nick
Thanks for looking at WAC510 access point. I guess you are looking the page 34 of this manual. http://www.downloads.netgear.com/files/GDC/WAC510/WAC510_UM_EN.pdf
Context here is router mode.
Are you looking for different VLANs in standalone mode? Let me know your what is the configuration you are looking?
Thanks
Raghu
- NickHWAspirantThis would be standalone mode.
I have a pfsense firewall / router, connected to a GS728TP. I want to attach an access point to the switch that can tag different VAPs to different VLANs from the switch to partition the traffic.
So the AP will be on a switch port with tagged ingress and egress. Each VAP would have separate SSID and communicate via a separate VLAN.- RaghuHRNETGEAR Expert
Hi Nick
Thanks
Raghu
