Preformed2019
Mar 31, 2022Tutor
WAC540 WIFI Scheduling issue
Hello guys
I have 5 WAC540 AP devices, which I need to set a scheduled SSID availability.
there is an option on the SSID setting to set a schedule and it will let you choose the time you want to set the SSID available time during the 7 days of the week.
the issue is that I want to set for 24 hours Monday-Friday and SSID been OFF during the weekend.
the setting does not allow you to set 24 hours, you need to choose the start time and end time and they can not be same, so I was able to set it for 23 hours, which left me with one hour downtime.
if you do not set up the time on the available date , it will be considered as your OFF time.
I have attached a image just to demoestratre.
anyone has any idea how to overcome this bad dilemma?
I don't have one to test with but can you change the minutes?
So set it from 00:01 to 23:59?
totally agree, it's bad design and need to have all day option. for now I have stopped using the SSID schedule as it is useless for my case.
if you have any update let me know.
thanks for your response.
- Geoff-NZApprentice
I am able to a least confirm they have resolved this issue in the WAX610. I know it won't fix your current AP, however, at least you know it's fixed if you upgrade to Wifi 6 access point(s).
